Browsing this Thread:
1 Anonymous Users
Rough Idle |
Need some suggestions! I have a 1977 B210. Car was running smooth as a babys arse one day and then i started it and the idle was real rough, I replaced just about everything that would cause the problem but it still has the rough idle. I have not replaced any emition control parts yet because I dont know where to start. Someone advised me to replace the charcoal cannister? Help me out please! ferg
Posted on: 2010/4/17 17:17
Re: Rough Idle |
From Atlanta, Georgia
Check your choke and make sure it's opening all the way at idle when the engine is warm. That was my problem.
Posted on: 2010/4/17 17:21
1981 Datsun B310 1973 Honda CB175 K7 Cafe
Re: Rough Idle |
From Lisboa-Portugal
I had and have sometimes that same problem with my A14 b210, One day is running fine and the other is running rough, but the last time i changed the ant-dieseling solenoid and adjust the mixture screw and is fine now, but from times to times i got to adjust it again, especially when i push him a little bit more!
Posted on: 2010/4/17 19:00
Re: Rough Idle |
Registered Users Contentmaster Usermaster
This problem is unlikely to be emission control-related.
Does it idle the same when cold, when hot, or both?
most common prolem is old-fashion vacuum leaks.
Posted on: 2010/4/17 21:03
