« 1 2 (3)
Re: Swaybar upgrade info
From New Zealand
Thanks for the offer but I wouldnt mind sorcing one over here. I dont want to have to pay for shiping it from Australia.. unless you want to pay for sipping lol
Posted on: 2010/4/22 1:58
From Wellington
If the bar is hitting the sump them its to far back, mount it to the chassie first (keep all the bolts only half done up), then mount to the bottom arms, the B310 links are longer so this helps with the extra wide bar.
Heaps of guys have done this swap......
Posted on: 2010/4/22 3:14
From Adelaide
We Make and sell 22mm sway bars to suit 1200 120y they are adjustable and will also clear CA/SR 13B.
www.maddat.com.au
Posted on: 2010/4/24 2:38
From New Zealand
Turns out there is a diffrence between a sunny ( b310 ) swaybar vs 120y swaybar. sunny is wider between the two bends on the straight section ( where it mounts to chassie ). Thats why i couldent get the bar to fit!
Posted on: 2010/7/1 7:33
Yes, the B310 engine bay is about 50mm wider than B110/B210. I would expect bumpers, anti-sway bar, etc. will be wider to suit.
The Datsun1200.com wiki says:
Upgrade
B210 has a swaybar larger than B110.
See: B210 Swaybar Upgrade
16mm (5/8")
B110: 17mm
B210: 18mm with A12 or A13
B210: 20mm with A14
22mm (7/8")
If you can find somewhere it says that B310 bar will fit B110, I will correct it.
Posted on: 2010/7/1 21:12
« 1 2 (3)
