a12 with sc12 and 32/36 idle problems
hey guys,
i have put a sc12 and a 32/36 webber on a a12. it starts then revs, seems like its going to settle then stall. i can rev it then it will die.
was woundering if this set up will run fine without the charger active? i was told it would be fine, heard that with EFI it runs like crap.
another thing is the vaccum lines, i have no idea whats what. there is 3 vaccum ports.
thanks for your imput.
cheers!
Posted on: 2010/4/26 9:58
Re: a12 with sc12 and 32/36 idle problems
i had a setup like this and the vac lines were blocked!!
are u running draw through or blow through??
i could run my setup on or off but it drove like #OOPS# off as it over fuled
Posted on: 2010/4/26 12:22
Car free
i think its draw though, the carby is on in before the charger. i think it has something to do with the lines but have no idea where the lines go. do you have any photos?
Posted on: 2010/4/26 12:48
i ran stock, stock pump, line, ran no return
Posted on: 2010/4/26 12:51
Car free
im running a elec pump. think its rated at 5-7PSI. so there is fuel for sure. think its the acclerator pump on the side, dont know where to get the vaccum for that? there is the to lines out near the base of the carby that im not sure of
Posted on: 2010/4/26 13:09
