Stock drivetrain fluid suggestions.
From Gawler, Sth Aust
Hey guys, I've just finished an engine swap and in the process I dropped all the trans fluid. I checked my workshop manual And couldn't find the fluid specifactions.
What gearbox oil have people used with a 56A 4spd? Also what diff oil for a standard sedan diff?
Cheers
Tom.
Posted on: 2010/4/28 0:03
72 B110 A14
71 B110 A12a (Parts)
06 380 VRX
Re: Stock drivetrain fluid suggestions.
Gearbox needs GL-4 gear lube.
In the diff you can use the more common GL-5 stuff. 80W-90 will do.
Posted on: 2010/4/28 4:31
From West of Seattle
I am using Redline MT90 in both the diff and tranny.
Posted on: 2010/4/28 5:50
Just make sure it is GL-4 so that it protects the older style synchros, which diffs don't need to worry about.
The specification: API GL-4MIL-L-2105
75W-90 is great.
Examples:
CHEVRON Multiservice Gear Lub. 75,80,90,140
ESSO Gear Oil GP80,90,140
MOBIL Mobilube EP or GX80-90, 90, 140
SHELL Spirax 75EP,80EP, 90EP, 140EP
SUNOCO Multipurpose GearLub. GL-480,90,140
TEXACO Universal Gear Lub.EP80,90,140
Posted on: 2010/4/28 6:31
Thanks for the input guys.
All lubed up.
Posted on: 2010/4/28 10:27
72 B110 A14
06 380 VRX
