wat turbo do i have??
it a garrette ar.48 can someone tell me if the is a stock ca or not
Posted on: 2010/5/8 11:18
Car free
Re: wat turbo do i have??
From Perth
The 1.8 L CA18DET was the last version of the CA engine to be released. It produces 169 hp (124 kW) and 166 lb·ft (228 Nm). It received a brand new DOHC aluminum head with 16 valves. The turbocharger was also upgraded to a Garrett T25 (.48 A/R) unit for increased flow capacity, and as such, was fitted with an intercooler to help prevent the onset of pre-ignition and/or detonation
Posted on: 2010/5/8 11:42
thanks so its ca18det stock
thanks
ill be on the hunt foe a t28 s15 one then
and some gtir injectors if anyone got some
Posted on: 2010/5/8 11:49
Car free
If you do find sum 2nd hand injectors make sure they are cleaned and flow tested... You will also need to buy new O rings for them as well.
Posted on: 2010/5/8 11:57
From Perth WA AUS
Good point, small details like that are often overlooked and can cause major headaches trying to find out why the car wont run properly, I've been there :(
Posted on: 2010/5/8 12:05
Datsun 1200 2Dr sedan.
i got a complete cadet that i was told i just needed to change a head gaskit and she would b sweet but ill look into getting a few things freshened up once its in and running
i also have 2 de's that may see a build to a ca18de+t
Posted on: 2010/5/8 13:53
Car free
