« 1 (2) 3 4 5 »
Re: engine rebuild kits
Looking for prices for the following;
Piston Rod Option 1 >
A12 +60thou (74.5mm?) pistons with between 5cc - 10cc dish, full floating with bushed rods to match. To work in hand with my high comp GX head (currently 20cc chambers).
Piston Rod Option 2 >
A12 oversize 76mm flat tops, full floating with bushed rods to match.
Also interested in pricing for;
Con rod bearings, Mains Bearing, Cam bearings.
Complete A12 Gasket Kit.
Funds are very low at the moment as I have just bought a disc brake setup. What sort of time-frame are you looking to order?
Posted on: 2010/5/4 14:09
From NW Sydney
I'd be up for an A15 rebuild kit at those sorts of prices. Happy to go for higher than std comp pistons if that's what the majority are doing
Posted on: 2010/5/4 15:26
SR20DET 1971 Datsun Bluebird 1800SSS Coupe - 11.58 @ 122.40 MPH GT2871R PLMS NIStune
Historic 1971 Datsun 1600 Wagon - L series nostalgia
Historic 1967 Datsun 1000 Wagon - A series resto
From sydney.nsw
clyons8 pm sent cheers
Posted on: 2010/5/5 10:02
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From sydney.nsw
any more interests pm me
Posted on: 2010/5/9 12:23
From South East Brisbane
So these kits include all required seals and just everything that's needed to rebuild the engine back to the stock standard?
Posted on: 2010/5/10 1:42
BigE is a reputed A Series race engine builder. These kits are for stock motors, worked motors and all out race monsters. The prices are really quite good.
Posted on: 2010/5/10 2:02
Count me in for one if you do a bulk order. Rather keen.
Posted on: 2010/5/10 2:34
From sydney.nsw
need more info on what engine combos u are after. eg a12/a14/a15 hi comp.std etc u can pm or call me 0412 864 741 ps need to get numbers of same type of kits to order in bulk.cheers
Posted on: 2010/5/10 3:50
From ACT
bige: I will be keen for a hi comp a14 package when the final numbers are in (I too am poor like clyons). Unsure of diameter pistons I need but fairly sure block is stock atm.
Posted on: 2010/5/10 7:17
Now riding dirtbikes:
Lots of A series Datto stuff for sale
From sydney.nsw
OK . getting close in orders 1ST UP is for A14 kits hi comp pistons. {$420 + freight} Need to confirm orders. PM ME OR RING to place orders & need sizes. Pistons will be +1mm/+1.5mm oversize, bearings can be std/.25mm/.5mm undersize.gaskets, cam bearings std. I would like to place order soon {20 sets is min} .big outlay for me. {serious people, no tyre kickers}deposit money get kit. lets go cheers.
Posted on: 2010/5/10 8:05
« 1 (2) 3 4 5 »
