Mikuni Solex Twin Carb Tuning & Setting Up
Has anyone had any experience with these carbs?
I purchased my 40PHH Twins jetted to suit an A15 stocker with a little cam work.
I have them on my worked A12 and I'm having trouble getting them to behave properly. At the moment I can't get them to idle consistently, it sounds like when they're idling there isn't enough fuel and they slowly die out unless I flick the throttle.
I haven't properly synchronized them at the moment as I can't even get them to run consistently to test (using the old school pipe-to-ear technique).
I understand the Pilot Screws (idle mixture regulates air-fuel mixture ratio during idle) are pretty important, what are yours set at? Mine are 1 and 1/2 turns out from seated.
Can anyone please help?
jpg  Twin 40s.JPG (129.51 KB)
7952_4bec914332f24.jpg 730X548 px
Posted on: 2010/5/14 0:56
Re: Mikuni Solex Twin Carb Tuning & Setting Up
Here is a quick video showing what I'm trying to describe.
Idle then Fuel Starvation?
Posted on: 2010/5/14 1:50
From sydney.nsw
what kind of fuel pressure do u have. maybe to much or not enough.
Posted on: 2010/5/14 2:16
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Mornin Bige,
Yeah fuel pressure is stock off the A12 Facet pump. But I have left the tap in from when I had the bike carbs on so the inlet and outlet of that are pretty narrow so I might pull that out and give it a go.
Problem is you need a base to start tuning these things and at the moment I can't keep the thing running for long enough.
When I had the hose to my ear on the first carb I heard a distinct knocking/popping sound, does this mean my tappets are out?
Can anyone also explain the carb backfiring?
I'll have another go at it.
Posted on: 2010/5/14 2:34
From sydney.nsw
check tappets.it could be a lean pop/knock . try a electric fuel pump with adjustable pressure reg. cheers
Posted on: 2010/5/14 3:04
So I removed the little tap, I think that helped.
The stupid thing was I had the front Jacked up, at least now I'm on a level!
Had a play with the Pilot Screws and it's running better, hopefully get it on the road soon.
I reckon that popping definitely is the tappets. I'll work on em now.
Posted on: 2010/5/14 4:00
