oval port head to a12?
hey guys just wondering if my oval port a15 head will bolt to a a12 with no modifications?
Posted on: 2010/5/14 8:57
Re: oval port head to a12?
From Freo
yes....
mabee...
early or late block, the oil galleries are different..
Posted on: 2010/5/14 8:58
A15 PSI Project Motor
'72 CB750k,
it came out of an 82 1200 ute the a12 so does it fit? thanx
Posted on: 2010/5/14 9:04
datsun a15 ute
From Freo
yes..
Posted on: 2010/5/14 9:16
'72 CB750k,
From Freo
Tech Wiki on the left <---- is your friend...
Posted on: 2010/5/14 9:17
'72 CB750k,
anyone else?
Posted on: 2010/5/14 11:34
datsun a15 ute
From Perth WA AUS
No prob's, need to change your inlet manifold though!
Posted on: 2010/5/14 11:38
Datsun 1200 2Dr sedan.
so it will bolt straight on? and why do i have to change manifold
Posted on: 2010/5/14 11:50
datsun a15 ute
From Perth WA AUS
Sorry, only if you have a round port manifold!
Posted on: 2010/5/15 6:29
datgx wrote:
anyone else?
Why, did you think Dundee1000 was telling fibs?
The A15 head will work directly on any of the 1974 & later engines. These can be readily identified by the distributor that is under the No. 3 spark plug.
The earlier A12/1200 engines with a distributor under No. 1 spark plug will require a mod to the head before the later heads can be used on them.
You will need the manifold that matches the manifold mounting stud pattern & the port shape.
Round port A12 inlet manifolds will not fit at all.
Round port A14 'economy' model manifolds will fit but the round port manifold negates the benifit of the oval port head.
Oval port manifolds will fit & work as intended.
Posted on: 2010/5/16 10:26
Love your Datsun.
Treat it well.
