DATO 1200 UTE REturn line
From the central coast, nsw
hey guys where is the return line on the dato 1200 utes? its a ca18det conversion. using the return from vent tank causes tank to not vent took the cap off the other day n sucked for air like it was drownin lol cheers guys
Posted on: 2010/6/28 12:37
Re: DATO 1200 UTE REturn line
From Melbourne AUS
they dont have one waz, you'll need to put one in
Posted on: 2010/6/28 12:56
1973 B110 A12
arh Sheit thats gay, i was readin some posts n was hoping that it wasnt true. lol devo gotta take the tank out again. any other way u know of doin it so i dont have to drain my tank??
Posted on: 2010/6/28 14:04
That's right. There is no return line on a Datsun 1200 even on the newer ones (at least through 1994).
The B310 Sunny has one. So do at least some B210s. They are used to keep the fuel cool via constant circulation, and not for excess pressure return.
If your engineer allows, you could externally vent the tank (as the early utes do) and then use the steel vapor line as a return line. It is a small line however -- is it big enough for your engine?
Posted on: 2010/6/28 18:24
