wheel question
From schofields nsw
hey
i am looking at buying a set of Sportmax 513 (Watanabe style)
15x7, +15 offset for the front
15x8 for the rear 0 offest.
just wondering if these will fit on my 1200 ute or will i be hitting anything cause i really like them and am getting them for a pretty good price cheers
jpg  rims.jpg (58.75 KB)
12365_4c32d6b116a33.jpg 373X344 px
Posted on: 2010/7/6 8:10
no replacement for datsun power
Re: wheel question
From Melbourne, Australia
you want about 110mm backspace, find an online calculator to see if these measurements you mentioned are in that ball park
you will need upgraded struts on front with that size wheel, for the tyre to clear the spring cup
also 7's is really fat for a 1200 front end, will need pumping to get clearance
8's on the back will require pumping also
having stretched tyres will help with that a little, 195 tyre is ample for the weight of a 1200 for typical applications, which is quite a skinny tyre for 8 inch rim!!!
1200 front end will also require footwell to be beaten back and front corner of gaurd to be modified out of the way of the turning circle
good luck
Posted on: 2010/7/6 9:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: wheel question
From Sydney, Australia
here's some pics of the 15x7's on my sedan.
i think utes have problems with the leaf springs being closer to the wheels???? and so you might have trouble with the 8's on the rear (MAYBE)
i am happy with the 7" all round though.
all my suspension/running gear is standard aswell. fronts fit with 8mm spacers even though i probs don't need to run them, i just like the look.
Posted on: 2010/7/6 9:26
B110 sedan
Re: wheel question
those tyres have some serious stretch which would be definately helping your fit
do you know your offset and tyre size?
Posted on: 2010/7/6 9:37
1200 Coupe Rallycar
Re: wheel question
15x7" +15 sportmaxx 513 rims
165/50R15 nankang tyres
look nicely stretched on the 7" rims
Posted on: 2010/7/6 9:42
B110 sedan
Re: wheel question
From schofields nsw
i was planning on stretching the rubber anyway which is good i guess. and i kinda expected to have to modifiy the front a little to get the front ones to fit but should look pretty mean with them on very much so with the 8,s on the rear.
i just wanted the advice before i bought them and then had to put them in the garage cause they dont fit.
Posted on: 2010/7/6 11:34
