floor pans
From sydney
can anyone tell me if the coupe ute and sedan floors are all the same.
thanks.
Posted on: 2010/7/11 9:00
Re: floor pans
No, they are different.
The Coupe and 2-dr sedan floors may be the same.
Posted on: 2010/7/11 9:09
Re: floor pans
From sydney
I have the nissan cd with the exploded view of the floors for everything, it looks like the rear floor in the ute is shorter, is this the only difference or are there other things,someone told me the front floor of the ute has bead rolling like the rear?? but I've never seen one like it ( I've only looked at 2).
Posted on: 2010/7/11 9:18
Re: floor pans
From Perth WA AUS
The Coupe and 2-dr sedan floors are different I think, due to fuel tank mounting position.
Posted on: 2010/7/11 10:45
Datsun 1200 2Dr sedan.
Re: floor pans
Well, yes ... but the front section might be the same. Except for the ute, 1200s have a two-piece floor. The front section is where the front seats are, then there is a section behind that.
* 74300-H1010 ASS'Y FLOOR-front Manual transmission COUPE
* 74300-H1010 ASS'Y FLOOR-front Manual transmission SEDAN 2-dr & SEDAN 4-dr
* 74500 ASS'Y FLOOR-rear
Posted on: 2010/7/12 2:41
Re: floor pans
From Melbourne, Australia
they would all be fairly similar, yes the ute floor would be shorter, and thats the only significant difference, never seen rolling in the floors. same design as sedans and coupes essentially. why are sedan and coupe different? (ive never noticed a difference) or is that just different for the rear seat also? i would think ute would be closer to sedan as they have the same door length?
Posted on: 2010/7/12 2:47
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: floor pans
From Armidale N.S.W
Pretty sure you will find all except utes have the same floor space especially when this guy is just talking floor pans not boot areas etc. If you look in a sedan and coupe or wagon you can see that there the same right back to the vertical edge where the rear seats mount.
Posted on: 2010/7/12 3:33
73 1200 wagon SOLD
Re: floor pans
Yes and under the rear seat is the Rear Floor panel.
Only the front floor panels are the same as the above part numbers indicate.
Posted on: 2010/7/12 3:42
