« 1 ... 3 4 5 (6) 7 8 9 ... 20 »
Re: EOI: Intake & Exhaust Manifold Flanges - Who wants some? Friday 16.07 PRICES UP
I'll confirm that I want when numbers are up (if ever?)
2 Round port Inlet
2 Round port Exhaust
ALL FROM MILD STEEL
Also, how different are the oval vs. round port exhaust flanges?
Posted on: 2010/7/16 4:54
Well I'm hoping that when we consolidate the orders from three companies to one there will be a bit of history there that they (the cutters) will do smaller orders for a good price. That's what I hoping for.....gee there's alot of 'hope' in this... Well that's what I'm trying to do, in the time that the Oval Ports are put through I'll follow up with the round ports and GX and other gear and insist that they do them for cheap, this extra time also allows for other people to submit interest.
Exhaust flanges are the same throughout the range and they have (the round port exhaust flanges) have been included in the request to the companies. I'll have to edit the list, thanks for bringing that up.
On another note; there are minor differences between each head casting this means that it that the flanges may need some cleaning up and port matching to suit their application. You'd be surprised how much an oval port Weber manifold will mis-align when you fit it without looking or feeling down the bores.
EDIT LIST UPDATE Friday 16th July
Oval Port Mild Steel
Gylezy - 4 inlet 10 exhaust
Lamb_daiquiri - 2 inlet 2 exhaust
Tongy - 1 exhaust
Heathbruce - 1 inlet 1 exhaust
Aegis - 2 inlet 2 exhaust
Tommo_73 - 2 inlet 2 exhaust
Davidbil - 1 inlet 1 exhaust
elemental_funk - 1 inlet 1 exhaust*
DatsAndy- 1 inlet 2 exhaust
lethal_john - 1 exhaust
clyons8 - 2 inlet 2 exhaust
benny - 2 exhaust
D – 1 inlet 2 exhaust
estyre - 1 inlet 2 exhaust
jmac - 1 inlet
DISCO_BOB- 1inlet 1 exhaust
DJF280 - 1 exhaust
LAGWAGON - 2 exhaust
ang94541 – 2 exhaust
2QK4U- 3 inlet 6 exhaust
Steveo- 1 inlet 1 exhaust
Diymark- 2 exhaust
Total inlet: 24
Total Exhaust: 46
Oval Port Stainless
lethal_john - 1 inlet
2QK4U- 3 inlet 3 exhaust
Total inlet: 4
Total Outlet: 3
Oval Port Alloy
clyons8 - 6 inlet
D - 1 inlet
benny - 2 inlet
tongy - 1 inlet
estyre - 1 inlet
DISCO_BOB - 2 inlet
DJF280 - 1 inlet
LAGWAGON - 2 inlet
ang94541- 2 inlet
2QK4U- 3 inlet
Total inlets: 23
Round Port Mild Steel
DatsAndy- 1 inlet
diymark - 2 inlet
D- 1 inlet
clyons8- 1 inlet
Total inlets: 5
Round Port Alloy
DISCO_BOB – 1 inlet
Total inlets; 1
GX Port Mild Steel
DatsunRepairSquad - 1 inlet
clyons8 - 1 inlet*
Posted on: 2010/7/16 5:27
Some misalignment is acceptable due to core shift and manufacturing differences and I hope no one will be upset if they may have to spend 5 minutes with a file - its just possible some people maybe under the impression that "LASER" cut means A1 fit where as it means that all the cut flanges are pretty much identical however, the heads will differ slightly.
Besides, when I port my motor I will open up the ports evenly until they just clean up and match the flanges, then make the ports 2mm bigger for the anti reversion effect (intake) and exhasut flange 2mm bigger.
Then depending on the hole sizes they cut for the M8 studs - they should locate accurately and the flange/ports should line up good. However, if they are like the extractors I brought (used like a 11mm holes as clearance for an 8mm stud) I'll just dowel pin the flanges to the block.
Speaking of which, what size holes did you specify for them to make Chris? I'm guessing 9mm? And they were laser cut not drilled?
Posted on: 2010/7/16 5:42
Re: Intake & Exhaust Manifold Flanges - Friday 16 July PRICES UP Page 5
From ACT
Hey Chris, great work on this mate
Can I get 1 each of the oval port inlet and exhaust in mild steel please.
Cheers, Jon
Posted on: 2010/7/16 5:58
Now riding dirtbikes:
Lots of A series Datto stuff for sale
@ diymark there is a misalignment that tends to be see a shift in the Y axis along (laterally) the head exhaust ports [against the bolt pattern] between different heads. 11mm holes provides enough slop that you can locate the flange without having to work the holes/ports as much or not at all.
Holes are made to 11mm and standard gaskets vary between 9.5 and 10.5mm holes. Ideally they ought to be blank so you can fit it perfectly.
The exhaust ports are slightly bigger as well to accommodate the variances.
I will take that on board and have a look through the heads again to see if there is in fact a change and if there is the holes will stay the same at 11mm. If they can be reduced I will do so.
@ thedevilshands, no worries champ I'll have you on there shortly.
Posted on: 2010/7/16 6:22
CONFIRMED LIST UPDATE Friday 16th July For Initial Prices
Tongy - 1 exhaust
benny - 2 exhaust
jmac - 1 inlet
DJF280 - 1 exhaust
Diymark- 2 exhaust
thedevilshands- 1 inlet 1 exhaust
Total inlet: 25
Total Exhaust: 47
Oval Port Stainless
Total inlet: 4
Total Outlet: 3
Oval Port Alloy
clyons8 - 6 inlet
D - 1 inlet
benny - 2 inlet
tongy - 1 inlet
estyre - 1 inlet
DISCO_BOB - 2 inlet
DJF280 - 1 inlet
LAGWAGON - 2 inlet
ang94541- 2 inlet
2QK4U- 3 inlet
Total inlets: 23
Posted on: 2010/7/16 8:42
From Castro Valley,CA USA
email sent
Posted on: 2010/7/16 8:50
Guys the prices are worst case scenario, the quotes aren't ready yet from final place but he's sure they won't be any more than what they were at. So that's good, just one place to deal with.
Please, no cash just yet, will update prices by Monday/Tuesday but if you can settle for what is now up there as the worst case scenario then say so and I'll put you into green.
Tongy - 1 exhaust
benny - 2 exhaust
jmac - 1 inlet
DJF280 - 1 exhaust
Diymark- 2 exhaust
Strop- 1 exhaust
Total inlet: 25
Total Exhaust: 48
Oval Port Stainless
Total inlet: 4
Total Outlet: 3
Oval Port Alloy
clyons8 - 6 inlet
D - 1 inlet
benny - 2 inlet
tongy - 1 inlet
estyre - 1 inlet
DISCO_BOB - 2 inlet
DJF280 - 1 inlet
LAGWAGON - 2 inlet
ang94541- 2 inlet
2QK4U- 3 inlet
Total inlets: 23
Posted on: 2010/7/16 9:02
Edited by clyons8 on 2010/7/16 9:20:33
Edited by clyons8 on 2010/7/16 9:48:50
Edited by clyons8 on 2010/7/16 9:59:46
ill take 1 set of ms oval port thanks chris
Posted on: 2010/7/16 10:13
Car free
Tongy - 1 exhaust
benny - 2 exhaust
jmac - 1 inlet
DJF280 - 1 exhaust
Diymark- 2 exhaust
Strop- 1 exhaust
Supafatto- 1 inlet 1 exhaust
lethal_john- 2 exhaust
Total inlet: 26
Total Exhaust: 51
Oval Port Stainless
Total inlet: 4
Total Outlet: 3
Oval Port Alloy
clyons8 - 6 inlet
D - 1 inlet
benny - 2 inlet
tongy - 1 inlet
estyre - 1 inlet
DISCO_BOB - 2 inlet
DJF280 - 1 inlet
LAGWAGON - 2 inlet
ang94541- 2 inlet
2QK4U- 3 inlet
Total inlets: 23
Posted on: 2010/7/16 10:34
Edited by clyons8 on 2010/7/16 11:23:29
