« 1 2 (3)
Re: oval port head on A12 block ,need help !!
As far as A series cams go, there are really only two types, early & late.
The front distributor cams [A10 & 1200] will interchange but will not work in 'rear distributor' cylinder blocks if you want to run a distributor.
All cams for rear distributor engines [1974 & later] are interchangeable & they can also be used in the early [A10 & 1200] engines, however with this swap the fuel pump will need to be removed & the hole covered.
See post #13
Posted on: 2010/8/19 17:27
Love your Datsun.
Treat it well.
« 1 2 (3)
