WTB Crank-pulley bolt and washer
From Central QLD Coast
Heya guys,
Sorry for the silly question, but where would I buy a new crank pulley bolt and washer from? Would that be through nissan only?
Just can't seem to find mine anywhere. Just when ya need it for the rebuild too!!
Cheers guys
Clay
Posted on: 2010/8/26 12:35
Re: WTB Crank-pulley bolt and washer
New from Nissan. I have some spares I'm pretty sure.
If you want I can get a pt number to you but there should be a part number in the wikiwikiwiki.
Posted on: 2010/8/26 13:10
Thanks for that Chris. I did see the part numbers in the wiki, was just hoping to avoid using our local Nissan joint.
Guess i'll get it ordered
Thanks again mate.
Posted on: 2010/8/26 23:22
Local Nissan place said they can't supply them any more, no reference in their system.
Does anyone have 1 in good condition that I could buy or know the dimensions of one so I can get one made/sourced from bolt shop?
Thanks guys.
Clay
Posted on: 2010/8/27 1:00
Crankshaft
12308-H1000 WASHER-PULLEY BOLT 1 A12 - $1.29
34.5mm OD, 0.64 in (16.2mm) ID, 8mm thick
12309-78200 BOLT-CRANK PULLEY 1 A12 - $5.73
M16 x 1.50 (fine) pitch
15mm diameter
27mm long
The head is 27mm hex and about 15 mm thick.
Torque: 15-16 kg/m (108-116 ft. lb.)
I used an extra-long bolt for more crank trigger, just used a 10.8 grade (extra strength) bolt. Dunno if that is overkill or not.
Posted on: 2010/8/27 2:54
