Browsing this Thread:
1 Anonymous Users
Re: A14 injectors |
Quite a regular
From Perth
sorted thanks for your help guys, the beast is nearly drivable. Just gotta learn how to drive now...
Posted on: 2010/9/1 3:16
Re: A14 injectors |
Quite a regular
From Perth
so finally got the ute onto a dyno, today was spent getting the maps sorted, anyone know what firing angle i should be using? at the moment it's at 400, also does anyone know how much a A14 will advance the timing when under load?
Posted on: 2010/9/7 11:03
Re: A14 injectors |
Registered Users Contentmaster Usermaster
A14 can go up to 35 degrees at high rpm under load (without boost)
Firing angle doesn't matter does it? The OEM systems run it 360 I think. Or maybe I'm wrong.
Posted on: 2010/9/7 19:22
