adjusting the diff..
From Brisbane
I have no time to check and gotta go to work soon!
Is it possible to adjust the pinon on my ute to move the diff /axel from left to right or vice versa??
one side the wheel is hanging out just a little more than the other side..
cheers
Posted on: 2010/9/20 2:11
Re: adjusting the diff..
Nope, adjusting the pinion won't change that.
it is normal for one side to be 8mm out from the other.
Posted on: 2010/9/20 2:17
Adjusting the pinion [bearings?] in the differential will not address a lateral displacement problem with the rear axle assembly.
I don't know why, perhaps it is a design feature, but lateral offset of the rear axle is common enough for me to wonder if it was designed that way.
Posted on: 2010/9/20 9:49
Love your Datsun.
Treat it well.
