A15 Fuel Pump vs A12 Fuel Pump. Is there a difference?
Is there a difference beteen fuel pump arms on the A15/14 units and the A12 units?
Not so much in the performance of the unit but rather the length and design of the pump arm.
Posted on: 2010/9/20 5:57
Re: A15 Fuel Pump vs A12 Fuel Pump. Is there a difference?
Posted on: 2010/9/20 6:04
From port elliot , SA
yea my A14 one has a longer pump arm than the 12 one iv got
Posted on: 2010/9/20 6:07
A12 and A15 pump is the same.
Pumps with the long arm fit 1974 and newer A12/A13/A12A/A14 and A15. Pumps with the short arm only fit A10 & A12 front-distributor engines (1966-1973).
at least that's what it says. Dunno if it's true
Posted on: 2010/9/20 6:23
I have later A12 with an A15 pump and it has damaged the lobe/cam slightly. Looking at the two the arm is certainly longer on the A15 pump, so in my instance that quote is wrong. No biggie, have already resorted to an A12 pump again.
I also have a feeling that my pump didn't have one of those phenolic spacers as well...
Posted on: 2010/9/20 8:15
There are two A12 engines, and they are very different from each other.
Posted on: 2010/9/20 16:57
Yes I noticed this when I put my two blocks together, side by side (both were the later type) first, most obvious difference was the location of the engine number stamp. Then there were a few other differences.
Posted on: 2010/9/20 23:14
