drag racing facts
From Melbourne, Australia
this email i got is bound to start some good conversation:
Subject: Impressive drag racing facts.
This will put motor racing right into perspective for you. These things
>are seriously impressive.
>One dragster's 500-inch Hemi makes more horsepower then the first 8 rows
>at Daytona (or Bathurst 1000).
>Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per
>second, the same rate of fuel consumption as a fully loaded 747, but with
>4 times the energy density.
>The supercharger takes more power to drive then a stock hemi makes.
>With nearly 3000 CFM of air being rammed in by the supercharger on
>overdrive, the fuel mixture is compressed into nearly-solid form before
>ignition.
>Cylinders run on the verge of hydraulic lock.
>Dual magnetos apply 44 amps to each spark plug. This is the output of an
>arc welder in each cylinder.
>At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame
>front of nitro methane measures 7050 degrees F.
>Nitro methane burns yellow. The spectacular white flame seen above the
>exhaust stacks at night is raw burning hydrogen, dissociated from
>atmospheric water vapor by the searing exhaust gases.
>Spark plug electrodes are totally consumed during a pass. After 1/2 way,
>the engine is dieseling from compression plus the glow of exhaust valves
>at 1400 degrees F.
>The engine can only be shut down by cutting off its fuel flow. If spark
>momentarily fails early in the run, unburned nitro builds up in those
>cylinders and then explodes with a force that can blow cylinder heads off
>the block in pieces or blow the block in half.
>Dragsters twist the crank (torsionally) so far (20 degrees in the big end
>of the crank) that sometimes cam lobes are ground offset from front to
>rear to re-phase the valve timing somewhere closer to synchronization with
>the pistons.
>To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of
>over 4G's. But in reaching 200 mph well before 1/2 track, launch
>acceleration is closer to 8G's.
>If all the equipment is paid off, the crew worked for free, and for once
>NOTHING BLOWS UP, each run costs $1000.00 per second.
>Dragsters reach over 300 miles per hour before you have read this sentence.
>Top Fuel Engines ONLY turns 540 revolutions from light to light!
>The redline is actually quite high at 9500rpm.
>To give you an idea of this acceleration, the current TF dragster elapsed
>time record is 4.477 seconds for the quarter mile. This means that you
>could be coming across the starting line in your average Lingenfelter
>powered "twin-turbo" Corvette at 200 mph (on a FLYING START) and the
>dragster would BEAT you to the finish line FROM A DEAD STOP in a Quarter
>mile distance!
[I think my brother added this to the email:]
"Yeah but put a corner half way up the track and it is absolutely stuffed."
Posted on: 2003/12/31 0:51
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: drag racing facts
From Warwick, QLD
Whoa Thats Awesome!!
Posted on: 2003/12/31 5:36
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Sounds about right to me.
At 44 amps per plug, the center electrode is nothing more than a welding rod. No wonder it has a service life of about 150 firings at full load.
Posted on: 2003/12/31 8:44
Love your Datsun.
Treat it well.
Not too shy to talk
From Oroville,Calif. USA.
That"s AWESOME!! Now,lets concentrate on-say,a 4 cylinder,yeh a well built L/Z 24 running on 24 pounds of boost,nitro-methane fuel-13:1 compression Let"s all see if we could compute the diagnostics/H.P. on that combination!!Then again,never mind-can you say"catastrophic-explosion"?(((Then again,American PRO-TECH"S said the same thing of the chrysler based HEMI.....HMMMM))) Tom S.
Posted on: 2003/12/31 11:35
From Adelaide
sounds right
Posted on: 2004/1/1 3:36
