Alternator earth??
From adelaide hills
okay on the back of the alternator (hitachi) there is a 2 prong plug, A and E connections. ive connected the plug, the live wire to the A connection and an earth to the E. The earth lead gets really hot after turning the engine over for a few seconds. and the car wont turn over with the wire disconected? any help? cheers
Posted on: 2010/10/4 11:06
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: Alternator earth??
From Perth WA AUS
Hope this pic helps but it sounds like you have a short somewhere.
jpg  18733.jpg (21.86 KB)
9665_4ca9b5c712649.jpg 400X299 px
Posted on: 2010/10/4 12:08
Datsun 1200 2Dr sedan.
Sounds like your engine earth cable is not connected.
When it is missing, it will go through any avaialble wire, including the small alternator earth -- or the clutch cable.
Fix it before the small wires burn up!
Posted on: 2010/10/5 2:25
From adelaide hills
i reckon that will be the problem! thanks heaps
Posted on: 2010/10/5 6:56
Here it is:
* Negative (-, aka earth/ground). Stock cable is BLACK with Yellow stripe. It connects directly to the engine block at the oil pump. The engine end of this cable also has a smaller black wire. This is the main body ground and connects to the body at the Horn bolt
Posted on: 2010/10/6 3:07
