custom radiators ?? who to use
hey guys,
today final fired up the sr20det in my 1200 ute so all the wiring and fuel system is complete, we used real long hoses and put a sr20 radiator infront of the car to fire it up but now im on the hunt for a good company that people recomend to build a custom size radiator
pls people give me your imput good or bad
Posted on: 2010/10/17 14:43
Re: custom radiators ?? who to use
pwr alwayss get a good wrap but are mega $$$$.
personally, the ebay ones (golpher i think they are branded) arent too bad. alot of forester guys are using them with no adverse affects. no need for custom, a sr20 rad shoud fit in between your chasis rails. im usng a stock ca s13 radiator.
Supafatto using a alloy ebay sr one... no issues, if anything its too cold! but thats was on stock a12
Posted on: 2010/10/17 15:09
yes but did u cut your top rad suport like most people do ? as i want that to stay normal shape
Posted on: 2010/10/17 20:06
Posted on: 2010/10/17 20:15
nope, neither of us cut the rad support panel.
i trimmed my shroud down to fit the fan up a bit higher, as it sits on the front of the rad.
Posted on: 2010/10/17 22:41
any chance of pics of it in yours so i can see where you located it?
Posted on: 2010/10/18 14:06
for more check out here
Posted on: 2010/10/18 23:58
thnxs for the pics champ, im alittle worryed about that hight i want it to go under that top suport so that it sits hard up against the front panel
Posted on: 2010/10/19 13:36
doesnt go under the top support stock, you have to trim the locating tabs down on the bottom tank. Mildman relived his front rail to allow room for the hose so it didnt rub on the rail. No issues here.
sits at this height and bonnet closes easily at this height
stock, it sat like this, and had no chance of closing.
you could also tilt it slightly like the jap drifters with their V moded radiators, but not as tilted, just so it will clear the bonnet if you have major issues. but then it may cause flow issues(shouldnt as its a sealed system) or foul on the engine pullys.
Not hard, if i did it, it must be easy ;)
Posted on: 2010/10/19 21:32
