Well I had a mammoth effort on Tuesday, Last chance before my b'day to work on the car
bought new power cable, remove starter motor an replace stock lead with new thicker/longer lead.
10 litres of new petrol in
mount return line
run power to fuel pump
replace vacuum hoses on intake manifold
buy clamps, install radiator, hoses and fill up
set up distributor
new intake and exhaust gaskets
fit alt, and alt belt
go over everything and tighten bolts check for leaks etc etc
here is an example of the rubber bike tube i used to stretch over the length of the radiator between and over the two mounting posts as this will sit on my lower radiator support and i dont want vibration or rattles from metal on metal.
crazy day but by about 7pm it was time to give it a kick over and see if we had created something...
Unfortunately no, meaning i haven't achieved my goal of getting the car started by my birthday (today), seems we have wiring issues to the injectors meaning they are not pulsing. They have power but are not getting the ground signal by the ECU to fire the injectors. At least thats what we think is the problem at this stage..
So i now have a complete engine that cranks over but does not fire, it has spark, a powered Ecu, coil/ign/dizzy all getting power, fuel pump is operational, radiator all good etc so at this stage im very very close.. so close yet so far :(
