s13 crossmember
guys i wanna swap my crossmember with my stock b310 will be ok is there a lot customization to be done ..
iz it a31 n s13 same size ??
Posted on: 2009/4/26 9:12
Re: s13 crossmember
From malta
after doing calculations from the manual i found out s14 will fit a b310. so at the moment i m work to get one. i m nealy at the point to buy one but still shipping is a problem for the seller. as i get it and i try it i give you a good answer which is sure
Posted on: 2009/4/26 12:30
Re: s13 crossmember
okay i wait for u lol
Posted on: 2009/4/26 14:29
Re: s13 crossmember
From malta
i had to shorten the s14 by an inch from each side to fit with a bolt passing right through in the chasis of the b310
Posted on: 2010/12/8 20:53
Re: s13 crossmember
got any picture ?? that will be nice..
Posted on: 2010/12/15 3:07
Re: s13 crossmember
From malta
this is how i got it fixxed after being shortened - in the image the spanner acts where the shaft should go to have the steering coloumn and the rack and pinion linked
Posted on: 2011/1/9 19:52
Re: s13 crossmember
what engine did u use sr20 ?? or stock A series...
Posted on: 2011/1/12 1:17
Re: s13 crossmember
From malta
sr20det rnn14 the one from the gtir coopled to an r33gtst box
Posted on: 2011/1/23 13:08
