Rims to suit 120Y
From Perth, Australia
Hi Guys....
I'm looking to replace the standard 12" rims with 13's. It seems 13 x 5.5" are mostly available, but I'm concerned about clearance issues, etc.
I don't want to use spacers, nor modify my calipers, ie something that bolt in and drives away.
are 5.5" rims fine or am I going to have problems ? 185/60 tyres will be fitted.
Thanks in Advance
Posted on: 2004/1/20 4:40
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
Re: Rims to suit 120Y
From Tas
They should be fine - always just make sure the rolling diameter stays the same that way your speedo will still stay acurate. This will change depending on your tyre profile.
I've actually got a set of 13x5.5's in the corner of the garage that used to be on the ute
Posted on: 2004/1/20 4:42
From Melbourne, Australia
yeah will be fine, you can go upto a 185/60 on a 14" wheel
Posted on: 2004/1/20 4:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thanks Buff...
the RD will be staying the same... 155R12 (actually they are 155/80R12) have the same RD as 185/60R13. Actually, it is 0.83mm different but that's nothing !
Thanks for the help. I won't have to roll guards or anythng, will I ?
1974 120Y Coupe
32/36 DGV Weber
5 Speed Gearbox
My website
actually what i said applies to having stanza struts but you will be fine with those tyres on 13" rims
Posted on: 2004/1/20 4:56
1200 Coupe Rallycar
From Tas
I wouldn't imagine so - not with 5.5's. If its standard ride height then I'd say definately not if its been lowered then depending how far you may benefit getting the guards lipped.
Just stick'em on and take it from there i believe they are a good vehicle as far as guard clearance goes.
Posted on: 2004/1/20 4:59
Thanks Heaps Guys... I'm not so worried about it now... I'll post the images once I get hold of them... got a $1700 windfall yesterday so might do a bit of shopping !!!
Posted on: 2004/1/20 5:32
1974 120Y Coupe
32/36 DGV Weber
5 Speed Gearbox
My website
From Tas
$1700 !! You Bast%$rd
Good Luck to ya....spend it wisely
Posted on: 2004/1/20 5:40
well I won't tell you about the $2500 christmas bonus from work then either !!!!
I assume spending wisely means spending on a Datsun !!
After the rims comes finishing off the interior (custom parcel shelf for audio, door trims, reupholsterd seats), some rust work, a little thing called an A14 and a new paint job ! I just finished deadening the undercarraige this weekend so it is all coming together !
Once I've made some progress on the 120Y, I can get back to the other toy, my XR2 Turbo convertible !!
Link
Posted on: 2004/1/20 5:44
1974 120Y Coupe
32/36 DGV Weber
5 Speed Gearbox
My website
From Tas
Man I'm in the wrong state! I'm gunna log on to Virgin Blue & book a one way flight over there
What profession r u in?
Posted on: 2004/1/20 5:48
