scrubing
From Goulburn NSW
Hi evereyone just put new tyres on datto ute 175/70/13 on the left side it scrubing on the foot well on full lock.When i put the 15"x4" will i need to bash it in
mcdat
Posted on: 2011/1/14 1:35
Re: scrubing
From Melbourne, Australia
IT'S HAMMER TIME
pretty typical to bash the foot well in by 20mm or so for clearance
Posted on: 2011/1/14 2:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: scrubing
From Goulburn NSW
can u just bash it in or do u have to cut it
Posted on: 2011/1/14 2:21
Re: scrubing
bash is fine
if your doing a super neat car you would cut and weld (have seen that also)
but just bash at the lump that is there if your happy to go that way, i would say 99% people bash it
Posted on: 2011/1/14 2:24
1200 Coupe Rallycar
Re: scrubing
From Goulburn NSW
what about on the right hand side if i bash it in will it affect how much the clutch etc goes in
Posted on: 2011/1/14 2:31
Re: scrubing
the bashing required is usually only right near the outer of the footwell, not right across, things like brake and clutch pedal are inside the engine bay anyway, not all the way out in the wheel well
have a good look before you start hitting, you will see this isn't an issue
Posted on: 2011/1/14 2:47
1200 Coupe Rallycar
Re: scrubing
From Goulburn NSW
i think i might let the guy that is doing the mods for me do it,borgy diff ca18det on and on
Posted on: 2011/1/14 2:56
Re: scrubing
From New Zealand
instead of beating up your ute you could just put some 60 profile tyres on it instead of 70's??
Posted on: 2011/1/14 5:12
Re: scrubing
From Goulburn NSW
what about when i pu the 15"on with 50 series on
Posted on: 2011/1/14 5:30
Re: scrubing
From Goulburn NSW
thats the problem its hitting about 4"s in
Posted on: 2011/1/14 5:52
