motor problem
From Goulburn NSW
Hi can anyone help me?just got into my datto started it and sounds like its starving for fuel ,checked the filter and its clean had a friend stand over the carby its getting fuel but keeps on cutting out whats the problem?its an a12.
Posted on: 2011/2/18 8:49
Re: motor problem
Could be many different things: air leak, electrical (spark problem) or even the fuel filter (looks cannot tell).
You might perform a fuel pump volume test. It's easy and requires no special tools. See Fuel pump pressure test. The pressure is not as important as the volume.
Posted on: 2011/2/18 9:06
Edited by ddgonzal on 2011/2/18 9:23:24
Re: motor problem
From Perth WA AUS
Is it cutting out only at idle or when reving it?
Posted on: 2011/2/18 9:08
Datsun 1200 2Dr sedan.
Re: motor problem
From Malaysia
DD, the link you posted, seems to be a bad link...
Posted on: 2011/2/18 9:11
Re: motor problem
corrected now
Posted on: 2011/2/18 9:24
Re: motor problem
From Goulburn NSW
its cuting out on idle and when reving it couple of backfires
Posted on: 2011/2/18 9:25
Re: motor problem
From Malaysia
maybe the ignition timing too retard?
Posted on: 2011/2/18 9:35
Re: motor problem
From Perth WA AUS
Have you checked the anti dieselling solonoid? And timing.
Posted on: 2011/2/18 9:37
Re: motor problem
From Goulburn NSW
there hasnt been a problem drove it about a hr before went to drive it again and then had the problem
Posted on: 2011/2/18 9:42
Re: motor problem
From Goulburn NSW
man i dont even know what that is i am a bigginer in the car game have always had new cars
Posted on: 2011/2/18 9:44
