mounting of a four point harness and seats ???
From sunshine coast
hi i have been trying to find out the correct way to mount a four point harness and my new seats.
it would be nice if any one could point me in the right direction.
i am currently looking at doing a few social club days and maybe a few drag days
i have searched through the cams manual but i cant work out the best way to mount the harness in the ute.
also do i need a cage to do such events?
can the mods be mod-plated
any help would be grate..
photo of seats will be up soon
Posted on: 2011/3/2 8:06
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
Re: mounting of a four point harness and seats ???
From Melbourne, Australia
what car?
Posted on: 2011/3/2 9:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sunshine coast
Sorry its a 73 datsun 1200 ute
Posted on: 2011/3/2 9:10
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
thats a tuff one, dont go down behind the seats for shoulder straps as if you are in an accident it will compress your spine.... other than that i cant help, would be impossible to put a harness bar behind seats so unless your going through the window in to the tray i cant see how it can be done
Posted on: 2011/3/2 9:18
1200 Coupe Rallycar
From Melbourne AUS
i do club sprints in my ute... no cage and no harness
i cant see how i can fit a cage and/or harnesses in the ute and still be able to fit in there myself.
i basically cant afford to move the seat from hard against the rear cabin wall.
a good fixed race seat will make a world of difference. theyre a prick to get in and out of but
definately worth it if your heading out on the track!
whats specs on the ute?
Posted on: 2011/3/2 11:41
1973 B110 A12
From Gold Coast
yeh there is no real safe way to mount a harness in a ute without a cage and taxi bar.. ange has already stated that you may not need one for the club sprints, and depending on how fast you ute is you prob dont need one for the strip.
Posted on: 2011/3/2 11:43
From sunshine coast
I'm still building it the body is 99 % done .
Almost finished the s13 disk conversion
Motor is the original a12 slightly worked, 1mm oversized pistons, flowed ported head, mild cam and a 10.5:1 comp.
I have kiehin fcr quad carbs for it aswell.
I realy would like to get a 4 point harness into it thoe surly some one knows ?
Maby ill have to ask the boys at the drags ?
Posted on: 2011/3/2 11:50
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From gold coast QLD.
You can get a harness in there,it just depends how tall/short you are.
Assuming you can bring the seat forward 100mm or so,the shoulder straps can be mounted to a steel plate which i would suggest be 300mm wide 50mm deep and 3mm thick you will need 2 one for inside and one for outside.Bolt this to the car under the window centred under the belt holes in the seat,i reckon the angle of the proposed mounting point should be around 25-30 degrees to your spine when seated which is OK.3 8mm bolts should be ok.Now drill two more holes right thru both plates and fit 2 eye screws/bolts for snap on clip fitment of your harness.Note;You will only be able to use the clip in style of belt and not the bolt in type due to the straight shoulder strap mounting point.
Thats about it,if you presented that fitment to me at a CAMS event and it was done well i would pass it to compete.
I have no idea if it would pass a transport dept blue plate
Posted on: 2011/3/2 20:48
From sunshine coast
Thanks bert that's the sort of info I've been chasing ill have to mount my
Seats in first and see if I can get 100mm out of it . :)
Posted on: 2011/3/2 21:05
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
From sunshine coast
here are the seats im fitting
jpg  seat conv.jpg (194.81 KB)
13691_4d734093b01f7.jpg 1552X2592 px
Posted on: 2011/3/6 8:07
73 1200 Ute
75 125 CR
84 250 CR
89 500 ktm
07 250 CR
vintage mx ....
