fs 1200 turbo setup will post
Hi I'm looking at going ca now so time to move on my almost finished turbo setup, u can see it running on YouTube there is a link in my project build, it's a t25 setup that will mount up to stock inlet, it will come with
turbo, exhaust manifold, inlet manifold, dump to flange that finishes under passangers seat, brand new water/methanol setup cooling mist setup with all the bits to make it go and is setup to run 50% meth 50% water and is good for up to 150hp with the jetting but u can buy bigger jets if needed, elec fuel pump and fuel pressure reg set at 3.5psi but is changable up to 7psi, all water lines and oil lines minus sump, fuel pressure gauge and boost gauge, 1 3/4 inch su that was new when put on this setup,
this setup is needing a dizzy to be modified or locked and it will bolt on, finish the water meth wiring and a tune and will be a fast upgrade, most of the hard work is already done, no thanks to tommoz's anything mechanical in Hastings, ( there's a plug for ya Tommo)
pics are in my project tread if u want to look or pm and I can post more, open to offers but keep in mind that in parts alone I've spent 1400 without labor, so u could grab a good setup cheap!!!
If doesn't sell here will be putting it on eBay in the next 2 weeks so be quick as it will go there
Posted on: 2011/3/5 3:59
Edited by supafatto on 2011/3/8 9:29:22
Car free
Re: Eoi fs 1200 turbo setup
From Sydney NSW
I'm interested, how much were you after? Cheers
Posted on: 2011/3/5 12:06
I'm looking at around 1000+ as I've spent alot more than that and most items were new on this setup
Posted on: 2011/3/5 21:41
Car free
Also please note this setup has been built for an a14/15 and would need some work done to it to fit an a12 as the heights are a little different
Posted on: 2011/3/5 21:52
Car free
Finn this setup may not fit in a 1000. Confirm that first before you buy otherwise you'll need to fork out for another manifold.
Posted on: 2011/3/5 23:22
From Sydney NSW
Yeah I had a look at the video seemed like there was a fair bit of clearance, what do you think superfatto, will it clear a 1000 bay? Maybe I could measure how much space is needed or something?
As for height maybe could just chop the intake pipe a little shorter.
Cheers
Posted on: 2011/3/6 22:45
If u measure wat u need to and let me know and I can measure and let u know! U could make a log inlet would be better I just wanted to stay stock so I could change easy if I got in trouble would be a quick change back to na
Posted on: 2011/3/6 23:00
Car free
Sl33per off of this site made the manifold for me and it's good
Posted on: 2011/3/7 1:11
Car free
Posted on: 2011/3/7 9:45
Car free
From Brisbane
that dash looks nice mate. goodluck with the sale
Posted on: 2011/3/7 9:56
