coughing at take off... help
Quite a regular
From Perth
morning fellow datto ppl's
my trusty little sunny has recently developed what i can describe as a cough or two when i go to take off from a set of lights or stop sign, ie from standstill.
once it coughs once or twice she moves off as smooth as silk, any suggestions as to why?
chuck.
p.s. replaced gearbox being replaced again, originla was faulty, what a pain in the arse. but no cost :)
Posted on: 2004/1/28 1:32
1980 sunny std dreaming of ca18det
2000 CBR600F4
Re: coughing at take off... help
From Tas
Hi Chuck,
Could be a few things we might need some more info but we'll sort you out
What is the idle like while you are sitting at the lights?
Is it standard Hitachi Carb?
Have you done anything to it at all recently under the bonnet (I always like to ask that just in case)
What is it like to start?
It could well be anything at this stage / maybe some crap in the carby, or points, incorrectly adjusted accelerator pump - still just guessing a bit at this stage - need a little more info please
Posted on: 2004/1/28 1:38
From Tas
By the way Chuck - its good to see a fellow motorcyclist on the site
Posted on: 2004/1/28 1:39
From Brisbane
check your timing first, if thats not the reason then your carb adjustment (tech info page)
Posted on: 2004/1/28 1:43
Quite a regular
From Perth
yes, standard piece of crap carb fully rebuilt 2 months ago, apart from that it is bog standard.
selling to my brother in 2 weeks as im heading overseas and im trying to get it runnin mint and with as little mods as possible as he has no mech know how.
standard = easy listings and parts.
I am going to get my mech to have a look at it when my new gearbox is in but was seeing if i can self diagnose before as it can be friggin annoying.
yes fellow biker, but its in the shop for sale due to overseas trip, thinking duke next, just too expensive for little performance.
P
Posted on: 2004/1/28 1:47
2000 CBR600F4
vacuum leak is the most likely cause.
Did it "cough" before the rebuild, or only since?
Posted on: 2004/1/28 3:23
Quite a regular
From Perth
it only started about 2 weeks ago and is getting worse, will check lines tonight.
makes sense.
chuck
Posted on: 2004/1/28 4:07
2000 CBR600F4
From Wanganui, New Zealand
I would be more suspicous of the accelerator pump. Check to see that there is a jet of fuel being pumped into the carb when you open the throttle.
Posted on: 2004/1/28 9:54
chuck, let us know what you find out.
Checking the accelerator pump is a great idea, like Niscoupe said.
Posted on: 2004/1/29 7:10
Quite a regular
From Perth
will do!
Posted on: 2004/1/29 9:35
2000 CBR600F4
