« 1 2 3 (4)
Re: is there any suspension upgrades for 1000's?
From Newcastle (NSW)
Oh yeah, I forgot about that!
I used some advice from the Red Ranger staff. I stuck the bushes in the frezzer overnight then quickly transfered them to the vice and drill them using a wood/blade drill bit. Took a couple goes to get the size right. I think the bit had to be about 2-3mm oversize to get the correct hole size.
Not hard. If I did it again I could modifiy all the bushes in about 30 mins. Simple stuff really.
Posted on: 2011/3/7 19:09
Racecar spelled backwards is racecar!
oh sweet thanks for that, so need to use a 16-17mm drill bit to get a 14mm hole?
Posted on: 2011/3/7 21:15
yep.try a 14 to start with and work your way up.
Posted on: 2011/3/9 8:10
« 1 2 3 (4)
