5 speed box but only 4 gears???
Quite a regular
From SA
so yer whats up with that?? has any one else had this? and would it be easer/ better/ cheaper to put a fifth gear in or get a 5 speed box?
Posted on: 2011/3/28 11:03
Re: 5 speed box but only 4 gears???
From Perth WA AUS
Huh? Could you explain the problem more clearly, I'm confused! :)
Posted on: 2011/3/28 11:06
Datsun 1200 2Dr sedan.
Perhaps you could re-read your post as if you were a complete stranger to see it as others see it.
I have no idea of what it is that you want or need.
Posted on: 2011/3/28 11:16
Love your Datsun.
Treat it well.
Quite a regular
From SA
sorry my bad. so take off in first then second third forth, and you go for fifth and it doesn't engage as such but goes into "fifth" but there is no gears to drive the wheels. just revs the engine as if in neutral.
Posted on: 2011/3/28 11:26
I think you have a smooth case 4 speed gearbox Stu? There was a 60 series 4 speed available.
EDIT: Posted at the same time sorry. Sounds like it's stuffed, fork out some cash for a rebuild!
I've had this b4 where the box was only a 4 speed but was so flogged out was like it had a fifth, either find out if it's a 5 speed and if so get it looked at if not just don't go for 5th
Posted on: 2011/3/28 11:29
Car free
Quite a regular
From SA
haha yer i try not go for it.. i just got a 4speed.. i just dont kno wat condition its in.. so im wondering if i should pull out the potential 5speed or rebuild the 4speed i just got??
BTW im new to dattos and the mechanic side of things.. but im keen on doing it all (with a lil help :D )
so cheers guys
Posted on: 2011/3/28 11:36
Stu I think I might be selling my 5 speed if the engine sells separately. Let me know if you're keen.
Chris
Posted on: 2011/3/28 11:42
Quite a regular
From SA
pm sent
Posted on: 2011/3/28 12:17
Stu is this the 4spd gearbox you got off me?
Did you replace the shifter bushes on it as well? This would stop ALOT of the slop and play.
If the gearbox is stuffed bring it back and we'll figure something out?.
Chris
Posted on: 2011/3/29 7:12
