Browsing this Thread:
1 Anonymous Users
Going to do a blow threw carb setup and need a hand |
From cairns
Hey guys im in need of help i am going to fit a blow through system to my a14 but i have never worked with this setup and im wnderin wat am i going to need for the system and should i run intercooler how much boost should i run should i run meth injection aswell oryeh in kinda desperation of info so if anyone could help that would b much appreciated cheers
Posted on: 2011/3/30 8:40
Re: Going to do a blow threw carb setup and need a hand |
From West syd
Need a blow thro carb. Rising rate fuel psi reg need at least 2psi more fuel psi then boost. Elec dizzy so u can retard timing going on boost that's as far as I got hope it helps
Posted on: 2011/3/30 9:54
From cairns
Have u got a blow threw system buddy and cheers for that it was heaps of help
Posted on: 2011/3/30 10:00
From West syd
I had one on a ke20. If u use stock motor run a intercooler helps keeps intake temps down plus more boost:) u can lock the weights in the dizzy to cheat put the vacuum advance line in to manifold n set timing when it hits boost timing retards ;)
Posted on: 2011/3/30 10:06
From cairns
Wat do u mean bout locking the dizzy how do u do that
Posted on: 2011/3/30 10:22
