l20b in2 1200 what cross member?
From Innisfail nth queensland
what is the best cross member 2 use when putting a l20b in2 a 1200 ute please help its a 85 model
Posted on: 2011/4/5 19:32
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
Re: l20b in2 1200 what cross member?
From Melbourne AUS
you'll need a custom crossmember for this
ie weld L series mounts to 1200 crossmember
Posted on: 2011/4/5 22:39
1973 B110 A12
best one is the one you already got. Just notch it and weld new mount plates... or section the oil pan to fit the unmodified crossmember.
If you are looking for one you can buy, i don't think anyone sells one. Nissan used to have one, but is no longer available.
Posted on: 2011/4/6 2:12
as ange said, stock 1200 x member, take off the stock mounts and weld stanza ones on- eaiset way but not that easy. few memebers have done.
my dodge spare is at jmacs currently, really need to get out there to pick it up still. The dodge one makes the L sit too high in the bay, so needs work to lower it in the bay.
Posted on: 2011/4/6 10:50
