Misc carb, & distributor questions....
From Seattle ,WA.
A few questions as I'm putting it all back together - I think I've got the dash wiring pretty well sorted out but other thoughts I'm having are:
1) What do you do with/for the vac advance when running a DCOE side-draft carb - stock A15 distributor, electronic ignition
2)linkage & accelerator cable setups for a DCOE - what are people using, will the stock cable work?
3)Firewall mounted tank vent/breather & hose connections, where do those get routed?
4)The 3rd port on the water outlet on the block I assume was connected to the stock intake maniford for cooling, just cap it off?
thanks!
Posted on: 2011/5/3 16:18
Edited by edp on 2011/5/3 17:43:36
Re: Misc carb, & distributor questions....
No need to connect it. Plug the advance diaphaghm for a neat look.
Yes.
Posted on: 2011/5/4 1:17
Re: Fuel Tank venting
You have a couple of choices:
1. Original system: Use the Flow Guide Valve and connect to air cleaner.
2. Newer 1200 system: connect to a Charcoal Canister
Posted on: 2011/5/4 1:21
Yes to stock cable. Here is what I am using, my manifold has a "cable tower" and then a DCOE-style bell-crank:
For a single-carb, people remove the stock Hitachi cable quadrant and bolt it to the weber throttle shaft.
Posted on: 2011/5/4 1:27
From Seattle ,WA.
Thanks Dave, obviously most questions related to not having a stock manifold. After looking at the charcoal canister pic I realized may even have one of these so that'll work.
I've got a bunch of linkage stuff to play with as well so i guess it fiddle time.
I assumed the engine will perform better with the vacuum advance connected but maybe thats not true & I can get away with just plugging it off.
Posted on: 2011/5/4 16:16
The engine will run OK w/o the vacuum advance. It will run better with it, assuming it's not broken.
Posted on: 2011/5/4 19:03
From Seattle ,WA.
there is a threaded port with a plug in it currently in the Cannon intake, if I put a vacuum connection in it would it function properly or is the stock dist. setup to operate off some advance curve that kicks in at some rpm range only?
Posted on: 2011/5/4 21:21
the distributor is setup to run from a carburetor port, not from intake port. Some Webers have this port, it would be above the throttle plate. But most DCOE does not have it.
Posted on: 2011/5/4 22:48
