« 1 2 3 4 (5) 6 »
Re: aido's 1200 ute
From Bendigo Vic
i got my cam back from melbourne to i got a new grind on it.
i bord and hone the block and resized the rod, i got new valve spring and put the head together. i took about 1kg off my flywheel,
i started balancing my motor i got the rod and piston good just waiting for the Clutch so i can do the flywheel clutch and crack at the same time.
Posted on: 2011/5/12 9:42
Re: aido's 1200 ute
Can you show some pics of how you balanced your rods and pistons?
Posted on: 2011/5/12 9:44
Re: aido's 1200 ute
From Bendigo Vic
i doin all the motor my self at work i try and get a pic 2moz,
piston is easy to doin just get them all the same weight, with the rod u have 2 get all the bigends the same weight then get all of the rod the same when u finish the bigend
Posted on: 2011/5/12 9:53
Re: aido's 1200 ute
From Bendigo Vic
i almost got my a15 together
jpg  a15..jpg (71.26 KB)
10708_4e48f6fc64cbe.jpg 720X540 px
Posted on: 2011/8/15 11:39
Re: aido's 1200 ute
Hey there. How much did those front brakes and struts cost? I want to up grade mine but dont really no enough to be asking the right questions. Thanks
Posted on: 2011/8/22 8:46
Re: aido's 1200 ute
From Bendigo Vic
hey i pay i think $2500 from datsport and they sent it all to my door
Posted on: 2011/8/23 8:33
Re: aido's 1200 ute
From Bendigo Vic
i got the head no the a15 tonite, how much do u think i would be ables to get out of the motor? any idears
aidan
jpg  motor a15.jpg (108.14 KB)
10708_4e5631aaab237.jpg 720X540 px
Posted on: 2011/8/25 12:27
Re: aido's 1200 ute
nice sump- need your own oil well for that thing. how much room is there to get oil filter on and off?
Posted on: 2011/8/25 12:39
Re: aido's 1200 ute
From Bendigo Vic
haha thanks i worked it out and i got a filter that will go on off just nice
Posted on: 2011/8/25 12:44
Re: aido's 1200 ute
i think theres a toyota filter, nice and short with same thread fitting for the a series... increase oil pressure a little too
might even have been ae86 ones from 4age- thats a bad memory guess but itt was definately a 4cyl toyota engine.
Posted on: 2011/8/25 12:57
« 1 2 3 4 (5) 6 »
