« 1 (2)
Re: URGENT INFO NEEDED - A12 Exhaust Manifold
From Auckland, New Zealand
OK now i'm ConFuSED?
Some people are saying now that the bolt patterns are the same?
i.e A12 is exactly the same as A14, i think they are totally different?
Who can DEFINATELY verify this?
Secondly will an A12 Exausht manifold bolt onto the A14 Head and i would like to use the A14 intake manifold.
I also thought that A14 did have a heatbox?
Any help is much apprecited - Thanks heaps so far!
Oh and thanks Datsunblue and Quinn for the info GREAT STUFF
Cheers
Posted on: 2004/2/10 1:21
#Datopower#
From Melbourne, Australia
the confusion is between exhaust and inlet
the EXHAUST is identical on ALL a12-15
the INLET varies, there is round and oval port, there is single stud between ports and then theres studs on the outside of ports
basically round ports use a single stud for 1+2 cyl between inlet ports and between 3+4 (2 studs total on top of inlet)
oval ports have a stud outside of both 1+2, and then also outside of both 3+4 (4 studs total on top of inlet)
a-12 is round port
a12gx is oval port
a14 can have both round and oval
a14gx is oval
a15 is oval
and then theres water ways
a-12 dont have em
a-12 gx do
a14 dont
a15 dont, except for a-15's from vanettes do (remember this to get manifold gasket for a-12gx)
edit [there could be slight exceptions, maybe on sunny (b310) motors or something, which im sure others will arise, but this is the info i have found from the work i have done]
Posted on: 2004/2/10 1:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
also as an added thing i found that with the a-15 inlet manifold from a vanette, the inlet runners actually raise slightly just after the head side of the manifold, i found his good for my turbo setup as i was able to cut off the water galleries from the bottom of the manifold to make a little extra clearnace, exatly enough for what i needed at the time
no-one will probably ever need that info but i thought i should share anyway while i was posting the above
Posted on: 2004/2/10 1:34
1200 Coupe Rallycar
Hey 1200rc,
Thankyou!!
This definately makes sense - great yes mine has oval inlet ports and no water ways.
Thanks very much!
Posted on: 2004/2/10 1:38
#Datopower#
« 1 (2)
