weld wheel offsets
From Goulburn NSW
Hi everyone thinking about putting some weld draglite wheels on my ute not concerned with the back but would like to put 15x4 on the front dont want them to stick outside the gaurds what offset am i after 1.875,2.25 or 2.50.
Posted on: 2011/6/8 11:15
Re: weld wheel offsets
From Gold Coast
What struts are you using? That will determine what back space you will need, the more track the bigger back space
Posted on: 2011/6/8 11:26
From Goulburn NSW
man i know nothing compared to u guys i am getting the struts from maddat along with a whole heap of other goodies its a tose up between weld and convopros,with the convopros 44lex told me that the 2 5/16 are the go so what is close to that in the weld
Posted on: 2011/6/8 11:44
From Gold Coast
Ah ok you getting the 5 stud 200b/r31 setup? The 2.25" ones are the closest to that. Best bet is to try and get a wheel off someone to test, don't do what I did and get the wrong wheels lol
Posted on: 2011/6/8 11:51
From Goulburn NSW
hi wardy i am going with the ultamite race coilover package which is a 200b/stanza strut with 5 stud ford pattern so u think 2.25 would be the go
Posted on: 2011/6/8 12:11
From Gold Coast
Pretty much the same setup as me, you will also need adjustable strut tops and lca's to bring the wheels inwards. Yep the 2.25" ones should be fine. There is only like 2mm difference between them and the 2 5/16 ones.
Posted on: 2011/6/8 12:22
