For Sale A12 flat top pistons 2 sets 1 set conrods and block taking offers want it gone
Not too shy to talk
I have 2 sets of brand new A12 flat top pistons for sale.
size 74mm one set has valve pockets cut to take any size cam or valves.
pistons are cast JCC pistons and of very good quality.
$270 a set deliverd
One set of A12 conrods,been lightend and balanced and not used yet.
$100 set
A12 engine block. has been hot tanked and bored to suit the pistons
and has valve cut outs in the cylinder bore to accept very large valve heads.
$80
A12 crankshaft,has been balanced,cleaned and journals linished still on std size.
$60
Located Melbourne SE
call charlie 0434 945 838
Posted on: 2011/6/10 13:06
Edited by Minisprint31 on 2011/6/17 11:50:22
Re: For Sale A12 flat top pistons 2 sets 1 set conrods and block
Quite a regular
hi interested in the pistons with the cut outs ..im in the uk so can you quote shipping
thanks Paul
Posted on: 2011/6/10 21:38
Not too shy to talk
Hi Paul express mail to UK will Be £30 you can go cheaper but it will not be registerd mail. Or if you are not in a hurry i will be in london as of the 3rd of july and can bring them with me as i am from the UK. What part of the UK are you from?
Posted on: 2011/6/11 8:47
From Near Bundaberg QLD
I'd like the ones with the cut outs if you guys cant get organised. if not then i'll have the plain ones. I'm in qld, postage to 4659. Do you live in the UK or aus?
Posted on: 2011/6/11 18:36
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Not too shy to talk
Hi, I live in Aus. the pistons are $270 including delivery to QLD.
thanks
charlie
Posted on: 2011/6/12 2:28
Do you know what size piston rings you have to use on them?
Is the A12 block an early block (dizzy up front) or late block (dizzy in the middle)?
What suburb of Melbourne are you in?
Thanks, Sam
Posted on: 2011/6/12 5:55
Not too shy to talk
Hi Sam,
It is a late block with the dizy in the middle, The rings are std size a12 rings.
i would advise people to fit total seal piston rings as they work really well.
I am located in Glen Waverley.
Thanks
charlie
Posted on: 2011/6/12 8:57
Not too shy to talk
guys please update the post.
Thanks
Charlie
Posted on: 2011/6/15 9:55
Hey mate, found someone closer with std sized pistons and some other bits and pieces I need, thanks for you help though.
Posted on: 2011/6/15 10:35
Not too shy to talk
No worries mate.
Posted on: 2011/6/15 11:29
