« 1 (2) 3 4 »
Re: BIGE "CLEAN UP" ENGINE PARTS SALE
From sydney.nsw
i'll get back to you on std a12 flat tops.cheers
sunny02 have heads call me
Posted on: 2011/6/13 8:30
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From sydney.nsw
racer135, yes i have a set of a12 std flat top pistons/rings.$260 + post. call me. cheers
Posted on: 2011/6/14 1:15
From sydney.nsw
heaps of used std rocker arm ass/sumps/rocker cover/timing cases/ altenaters/points dizzys/heads/blocks/cranks/cams/conrods etc. and more. cheers
Posted on: 2011/6/14 9:33
Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
From sydney.nsw
Engine Rebuild Kits A10/12/14/15.kits include; cast pistons,rings,bearings,gaskets.timing chain & tension er(gears if needed)can make up kits to suit your needs.all new and good quality. (some kits can have higher comp pistons available as well) can post at buyers cost. Prices start from approx $420.00 per kit to give u a estimate. cheers
Posted on: 2011/6/14 10:16
From sydney.nsw
all pm replied.cheers
Posted on: 2011/6/15 1:43
Re: Re: BIGE "CLEAN UP" ENGINE PARTS SALE/ENGINE REBUILD KITS
have any elec dizzy's? thanks
Posted on: 2011/6/15 3:28
From sydney.nsw
yes, the unknown one with built in module(was in my car and works) cheers
Posted on: 2011/6/15 4:27
Edited by bige on 2011/7/11 10:58:05
From sydney.nsw
BUMP
Posted on: 2011/6/16 7:01
Edited by bige on 2011/6/16 7:20:05
"A15 +040cast pistons & rings dish (new) $250"
Hi interested in the above,
A) How deep is the dish in these slugs or can you give me the "CC"?
B) What brand / part Numbers?
I have an A15 ex race motor, running A14 Pistons (unsure why, maybe they have have crowns machined down for higher CR?) but one pistons is cracked, and two other have skirts broken off...
Looking for cost effective replacement set of pistons .040" / 77mm
Posted on: 2011/6/17 9:18
From sydney.nsw
pm sent KitchNZ
Posted on: 2011/6/17 14:59
« 1 (2) 3 4 »
