Exhaust Manifold Spring
From Sydney, NSW
Hi I got sent a second hand exhaust manifold.. it is the flap type with the spring..
next to the spring are 2 washers that are moving freely and I was wondering what does the little bent bit at the end of the spring hook up to? I can't really see how it would work? any info/pics would be most most appreciated!
Thanks,
Tom
Posted on: 2011/6/28 0:02
Re: Exhaust Manifold Spring
Hi Tom, see Heat Riser
Posted on: 2011/6/28 4:59
From Sydney, NSW
Thanks so much for the reply and the tech wiki article!
the only question i have left about it is what should i do about the random washers I have between the coil and the manifold body.. i.e the non weight side..
and is there supposed to be a little spring between the body and the coil thing?
are you supposed to be able to turn the flap by hand? because i most certainly can't!
Cheers,
Tom
Posted on: 2011/6/28 5:07
