Engineer Cert brisbane, Please Help!
Quite a regular
From Hervey bay, QLD
I'm in the process of buying an A14 powered 1200 ute but from what the guy says it looks like it's had the engine number from the original a12 stamped onto the new engine. I had already enquired with insurance companies to see who would cover a 17yrld with a 40yrld car thats had an engine swap, the only insurer that would was Just Cars and i had planned to go with them. I'm going to have to get it RW either as an a12 (hoping it was a good stamp job)but then i dont think ill be able to get covered by Just Cars as they already have it on record as an A14 and if i have an accident they are going to pay special attention to the engine and i doubt i'll be covered. OR. Get it engineered as an A14 which i hope wont be too expensive as im already stretched tight to buy/insure/register this vehicle. Can anyone help, is there a cheap engineer in brisbane that will help me out, and how much will this usually cost?
Posted on: 2011/7/4 4:46
Re: Engineer Cert brisbane, Please Help!
Quite a regular
anyone...
Posted on: 2011/7/4 5:38
If it has an A12 in it now, why do you have to get it registered?
Maybe you worry too much. It says A12 right on the engine. That's the factory engine type.
Posted on: 2011/7/4 5:55
From ACT
Heh heh wait till you get the car then worry about that stuff.
When I went into ACT motor registry with an A14 in my 120Y in they didn't even blink. Just wrote the new numbers on the papers.
In most states an A14 is considered a replacement for an A12 so I dunno why they re stamped the A12 block (2 options spring to mind: 1 - Ex race engine/cheating and 2 - Are you are buying an A14 powered 1200 at all).
All you can do is go with the best available information. If the block you pay for says A12 then you "must" consider that you are paying for an A12 and so will insurance peeps.
It doesn't matter if you "think it might" be an A14 when you get a quote or whatever. Just go off the numbers and you will be fine.
edit - beat me to it DD!!
Posted on: 2011/7/4 5:58
Now riding dirtbikes:
Lots of A series Datto stuff for sale
Quite a regular
So just go with it? The guy im buying it of said that the older bloke he bought it of swapped in an a14 and just stamped the original engine numbers on it. What im thinking is that if i have a crash and Just Cars are suspect that the engine is actually an A14 instead of an A12 as i've told them, they will probably pay more attention to the engine and strip it down, if they do that they'll see that its an a14 and i'm liable for Everything....
thedevilshands, That sounds great im going to call QDOT and see if they need a engineer Cert for an a14. Fingers crossed
Posted on: 2011/7/4 6:16
Quite a regular
They do need and engineer Cert on any engine swap that wasnt a standard engine in Aus as i'd thought. They put me on to some people who do mod plates at $88 per item so it looks like that'll have to be it.
Posted on: 2011/7/4 6:52
Quite a regular
So looks like the man to go to is Sethel Somethingarother in brissy, 07 3800 6757.
Posted on: 2011/7/4 7:11
From ACT
Lol you do worry 2 much!!
Just cos the guy you bought it off thinks the guy before him might have stamped an A14 with an A12 engine number doesn't mean you have to get this engineered.
As far as you can tell, and that anyone can prove without pulling it down, including youself, the engine is an A12.
Best not to worry.
I would think that if you tell them you have an engine with funny numbers they would have to take the engine off you as it could potentially be stolen or some crap like that.
You are gonna rock up to the engineer an he'll be like u want me to engineer the original engine in the car??? Sure man give me $88 and off you go!!!
Posted on: 2011/7/4 7:13
Chances of a datsun engine being stripped to measure cubic displacement woul be 1 in a million.
You'd have other issues to worry about before the power of an a14 brought you onto trouble with s company that insures 1000hp skylines and such openly.
Also insurance is usually based on duty of disclosure. You state when your doing the quote as well as by the policy that all the modifications on your car are legal and rwc. Reason why everyone's not wanting to touch it is because it may not be lgal and rwc as you have advised them.
In some cases it's actually condoned by road transport to stamp your old number onto a replacement engine that bares no such number. It has happened with older cars that have had replacement engines, if it's missing then it may be allowed to restamp it If approved by road transport auth. They do it with vic/chasis numbers some times too.
Posted on: 2011/7/4 7:16
How likely is it that is really is a A12, with the seller saying "hey it's really an A14, worth a bit more, eh?".
Posted on: 2011/7/4 7:23
