« 1 (2) 3 »
Re: Exhaust Manifold to exhaust down pipe what size studs?
From Sydney, NSW
GASKET NEW P/N 14035 K7700 $30.80 EX JAPAN NIL AUST STUDS EX JAPAN $2 EACH NOT ON FILE IN AUST POSSIBLE MULTI PACK OF 10
Posted on: 2011/7/5 1:22
From Sydney, NSW
WTF! $30 for a gasket! is it made of platinum?!
From Sydney, NSW
and it's the wrong gasket!
From Sydney, NSW
do you happen to know if 14005-18000 is just standard gasket paper?
nil stock apparently
Posted on: 2011/7/5 1:50
It is not paper. This is a gasket for the exhaust stream. It is like the exhaust manifold gasket (fireproof).
Posted on: 2011/7/5 3:51
Yes, the manifold is normally purchased as a unit: with intake and exhaust together.
If you buy separate pieces it is trouble.
Posted on: 2011/7/5 3:53
From Sydney, NSW
Any idea if you can buy a type of gasket paper that would do the trick?
I actually found the parts on everythingg35.com 14005-18000 under that part number.. were much more reasonable than ordering the gasket from nissan.. they said $30!
Posted on: 2011/7/7 5:52
From ACT
Use hi temp gasket goo mate
Posted on: 2011/7/7 6:23
Now riding dirtbikes:
Lots of A series Datto stuff for sale
From Sydney, NSW
instead of a gasket? or included with the gasket?
can you basically just buy a tube of high temp exhaust gasket liquid stuff?
Posted on: 2011/7/7 6:28
From ACT
yup thats it mate, no gasket just follow directions on packet.
My 200B SSS has it on the same place, looks to be very many years old and no leaks or anything.
Paper gaskets would burn up and be useless anyway
Posted on: 2011/7/7 6:33
« 1 (2) 3 »
