Browsing this Thread:
1 Anonymous Users
Alternate fit A-series oil filters? |
From Atlanta, Georgia
So the other day at work, I coincidentally found that a 1993 Infiniti J30 uses a PN/ 2827 oil filter, which is the same as theA series oil filters, but also showed in the fram brand a different filter number, being a 3682. The differences seem to ONLY be the location of the filter gasket, moving to the outside of the filter body. In my parts store system, the only filter it shows to fit the A motor is a P/N 2827, however because the J30 uses a 2827 or a 3682, they should be interchangeable, correct? This would allow me to use any filter for the J30, and I'd have a wider range of available filters for my A-series rather then just a small breed.
Posted on: 2011/7/15 9:26
1981 Datsun B310 1973 Honda CB175 K7 Cafe
Re: Alternate fit A-series oil filters? |
Registered Users Contentmaster Usermaster
Hi metalmonkey47, There are dozens of oil filter that work with the A-series. Starting with good old Ford F1 filter. Quote: ELEMENT-oil filter, cartridge. Threads: 3/4-16 UNF, Outside Diameter: 80 * PRO-TEC 150 $2.43, BECK/ARNLEY 0418723 $4.41, BOSCH 72133 $4.41, WIX 51361 $4.67, ACDELCO PF34 $4.88, FRAM PH3639 $6.00
TIP: Use a Ford oil filter #F-1 on your 1200. You only need to use a rotary grinder to grind 1/4 inch off the engine boss. The rotary bit cuts cast iron like butter. Then it fits. * bigger capacity * In the US, it is less expensive than the small "import" filter
Pretty much any A-series filter fits. Or any with the same threads and diameter. Few are too long for the A12.
Original Length: 145, replaced by 115 length * Nissan: 15208-H1010 115 height $8.27 USD ** formerly: 15208-13211 , 15208-13212 145 length * Tokio FL-208(Y) 1300, 1500 C-201 * FRAM ExtraGuard PH3639 * Purolator #L30042 * Deutsch #D601 * Purolator PER42 (DATSUN,TOYOTA) * Purolator L30042 * Pennzoil PZ8 * Champion PH2822,2825 * AC PF1026 (?)
Newer A-series filter PN 15208-H8920 (Length: 130) * Tokio FL-208 * C-208 * CKO-1218 * SP-842 * FC 208 * 15208H8923 * T-3135
NISSAN SUNNY,CHERRY (Length: 100) * FL-207 * 15208-H8916 * 15208-H8911 * 15208-H8994 * SP-929 * 15208-H8917 * 15208-H8912 * 15208-H8905 * 15208-H8904 * 15208-H8903 * 15208-H1011 * 15208-H1010 * Fram ExtraGuard PH3682 * Fram ToughGuard TG3682 * Fram DoubleGuard DG3682 * Fram X2 XG3682 * Purolator L24457 * Pennzoil PZ27 * Champion PH2827,2903 NISSAN,SUBARU * AC Delco PF8903 * Wix 51361 * Champ PH2827 spin-on oil filter used on Nissan 200SX 4 cyl. 1.8L, 2.0L F.1.,& V6 3.0L F.1. engs., 300ZX V6 3.0L eng., M-10 Sedan 4 cyl. 2.0L F.1.eng, Maxima V6 3.0L F.1.eng, Micra 4 cyl, 1.2L eng., Pathfinder V6 3.0L F.1.eng.,Pickups V6 3.0L F.1.eng., Stanza 4 cyl. engs. Van 4 cyl. 2.4L F.1.eng.,Subaru 4 cyl. 1.6L & 1.8L, XT-6 Turbo 6 cyl. 3.0L Turbo. (Replaces: Nissan 15208-H8903; Subaru 15208-AA000) Equivalent: AC: PF1232 CHAMP: PH2827 FRAM: PH3682 MOBIL: MO-4457 MOTORCRAFT: FL-839 NAPA: 1361
B210, B310, F10 * Fram ExtraGuard PH46 * Purolator L10168 (Audi 5000 Turbo) * AC DuraGuard PF34: PF34 #6437982 FITS: 74-82 DATSUN F10,210,B210,310; 78-80 FORD FIESTA L4-1.6L; 71-73 PINTO L4-1.6L; 72-75 CHEV LUV TRUCK; 83-90 MERCEDES-BENZ 4 CYL; 70-79 SUBARU; 86-90 TOYOTA VAN 2.2L, 69-80 W/KC, RC ENGINES, 81-84 STARLET, 84-85 TERCEL L4-2.0L. THIS FILTER REPLACES FRAM PH2825, PUROLATOR PER64, WIX 51034 & MOTORCRAFT FL13
Posted on: 2011/7/15 9:31
