Gx twin hitachi manifold question
From Brisbane, Australia
Hi, I have a a14t manifold with 4 bolt hitches and also a gx manifold but for two bolt carbs but without carbs. I was wondering if it will be ok to use the the 4 bolt carbs on the two bolt gx manifold. Will be going on a gx head a15 block.
Thanks Geoff.
Posted on: 2011/7/21 2:28
Re: Gx twin hitachi manifold question
Should be okay. But I can't be sure.
Is there a reason why you don't use the A14T carbs with their own (A14T) manifold that you have there?
Posted on: 2011/7/21 2:54
I don't think the a14t manifold wil line up properly with the gx head. The inlet ports look to be a bit higher up.
Thanks
Posted on: 2011/7/21 3:01
Oh okay, I don't know much about the A14T stuff. You wouldn't happen to have a picture of both manifolds side by side would you?
I guess what you need is an A12T manifold.
Posted on: 2011/7/21 3:14
Um I don't know about the a12t but bought th gx manifold to line up with the gx head, but it didn't come with carbs. I thought it might be ok to mount the 4 bolt carbs just using 2 bolts.
Thanks
Posted on: 2011/7/21 3:22
Trying to upload photos, always have trouble with this.
Posted on: 2011/7/21 3:56
A14T uses standard A14 head and the twin-sidedraught manifold has standard A14 oval ports -- smaller than A12GX ports.
Posted on: 2011/7/21 4:11
a14t
gx
Posted on: 2011/7/21 4:15
Edited by DatsunRepairSquad on 2011/7/21 4:31:18
Edited by DatsunRepairSquad on 2011/7/21 4:32:11
Edited by DatsunRepairSquad on 2011/7/21 4:33:05
That's it. Just remove the image width stuff.
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=23468[/img]
EDIT. whoops gimme a second.
Here is the actual image link, you can tell by the 'jpg' file reference: http://datsun1200.com/uploads/photos/23468.jpg
Then when you link it in you either remove the "width=300"[img width=300]http://datsun1200.com/uploads/photos/23468.jpg[/img]
so your link should look like this [img](insert link here)[/img]
Posted on: 2011/7/21 4:21
img width is OK
You need the img URL (ends with .jpg) -- not the photo page URL.
Posted on: 2011/7/21 4:23
