« 1 (2)
Re: Gx twin hitachi manifold question
From Brisbane, Australia
Unforunately to original picture showing them side by side is to big so just cut these smaller images out. Don't know if you can see the difference?
The holes for the 4 bolt carbs seem to line up also checked with 1 3/4 su's 4 bolt, they line up as well.
Thanks
Posted on: 2011/7/21 4:36
Yes, 4-bolt Hitachi and S.U. pattern is the same as two bolt. It would probably bolt up sufficiently tight.
GX ovals are 36 mm high - above the mounting bolts
A14 ports are 34 mm high - below the bolts
Posted on: 2011/7/21 4:42
« 1 (2)
