Nissan HB12 Sunny with an E15 engine - troubles
From Harare, Zimbabwe
Hey guys....
I know this is not exactly a Datsun, but I do have one! This Sunny is my wife's daily driver, and has a couple of engine troubles...
A bit of background on this car:
The company I worked for bought this car with a leaking water pump. It was changed but the engine wasn't even given an oil change. After a couple of months, the timing belt snapped when I was driving it & bent a couple of valves. I had the head recon'd & the mechanic that put the engine back together said that it needs rings, bearings & seals. Apparently the bore was still ok , had no lip.
Where my problem comes in is with the way the engine sounds. I know that these engines idle very quietly when is perfect condition. This one sounds like something is loose... The mechanic tried tightening the rockers? followers? then the engine wouldn't start/run. When he loosened them again, it started up. He said it could be worn followers or a worn camshaft. The sound speeds up/slows down with the engine speed & sounds like: prrrrrrrrr!
I'm planning on changing rings & seals soon (it's leaking quite a bit of oil & I check the level every few days)
A few weeks ago I saw an HB12 Super Saloon with a turbo motor, aircon & power steering. I would eventually like to get that engine or maybe another that can give me "full-house" options, any ideas on the engine?
Am I barking up the wrong forum? Does any one know a forum I could get some pointers on for this car?
Thanks for listening guys!
Posted on: 2011/8/4 19:27
"Make a plan!!!"
Re: Nissan HB12 Sunny with an E15 engine - troubles
Hi Ethan,
If it was quiet before the timing belt broke, and then noisy after "reconditioning" then the mechanic missed something. One of the rockers could have been bent in the mishap. E-series is OHC but uses a rocker shaft.
If the engine requires:
* Head to be fixed for noise
* Rings
* Bearings
Then YES, I agree find another engine and swap it in.
E15ET is a desirable engine, and many have been swapped into Datsun 1200. Your newer Sunny will like it too. The safest method is to buy a Super Saloon -- you can test it and drive it before you buy -- and sell your Sunny. Or you can swap the engine in, but there are many parts involved and if you have to pay a mechanic to do it you should have 100% confidence in him.
Posted on: 2011/8/4 22:30
