New wheels!
From Los Angeles,CA
New wheels for the Coupe! I loved the Libres but they were 13x7's and the tires seemed to want 8's sooo.....
jpg  DSCF4769-lo.jpg (186.97 KB)
8618_4e3e2d2f6f6a4.jpg 1448X813 px
jpg  DSCF4773-lo.jpg (179.16 KB)
8618_4e3e2d5ec49c7.jpg 1500X1125 px
jpg  DSCF4772-lo.jpg (182.03 KB)
8618_4e3e2d8557f51.jpg 1500X1144 px
Posted on: 2011/8/7 7:15
Re: New wheels!
nice!
Posted on: 2011/8/7 7:19
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Re: New wheels!
Does it handle different?
Posted on: 2011/8/7 7:20
Re: New wheels!
From Los Angeles,CA
Only got the one mounted this afternoon... I need some longer wheel studs for the front because I need a small 1/8" spacer so the tire doesn't rub the strut.
Posted on: 2011/8/7 7:27
Re: New wheels!
Longer Wheel Studs for the stock 1200 disc brakes:
* 40222-15C01 GC22 Van $2.12 USD each
* 43222-0B001 V40 Quest $9.47 USD each
* NAPA/Balkamp 6412785 $2.29 USD each
* Dorman 610-403 (610403) $1.34 Rockauto
Type: Serrated Stud
Thread: M12-1.25
Knurl Dia.: 12.90mm
Length: 45.5mm
Shoulder Length: 15mm
* Infiniti J30 front 1995-93
* Nissan VAN Front 1988-87, From 1/88
* Nissan QUEST Rear 1998-93, From 1/88
Posted on: 2011/8/7 7:41
Re: New wheels!
From Los Angeles,CA
Will those fit without mods? Doesn't the back of the 1200 stud have a crescent cutout to clear the hub?
Posted on: 2011/8/7 7:48
Re: New wheels!
The rear studs have the crescent.
Front ones do not, but are the exact same as 510, 240Z and many other Datsuns. These studs are 1/2" longer than stock. There is one other, the NISMO studs which are even longer.
Some guys fit S14 studs but those are a little smaller in diameter. Reportedly they work OK too.
Posted on: 2011/8/7 8:05
Re: New wheels!
From Los Angeles,CA
Excellent! Thanks DD!
Add: I just looked at a rear wheel stud ( all I've got to look at just now) The shank isn't splined and is 12.5mm in diameter. Those longer studs are splined and 12.9mm in diameter. Is that consistent with a standard 1200 front stud?
Posted on: 2011/8/7 8:12
Edited by LOWTECH on 2011/8/7 9:14:42
Edited by LOWTECH on 2011/8/7 18:46:11
Re: New wheels!
sick wheels
Posted on: 2011/8/7 13:09
Re: New wheels!
From Melbourne AUS
that stance is tough as!
theres nothing like flares when they are filled out properly! especially on a coupe
whats the tyre width?
Posted on: 2011/8/7 13:15
1973 B110 A12
