Sunny Struts & Stub axles same as Stanza ???
Does anyone know if sunny struts will take the hilux calipers and stanza discs?? I can't find any info to say they won't but I haven't heard of anyone running this set up??
Posted on: 2011/8/13 5:54
Re: Sunny Struts & Stub axles same as Stanza ???
B310 Sunny came with two different size struts. I believe one is interchangable with A10 (Stanza/Violet/510). The other is probably not.
Posted on: 2011/8/13 7:01
The ones I have are 49mm tubes which is the same as stanza, 200b's ect as far as I know. The sunny stuts have the smaller springs though which can be helpful. Could make for some easy brake upgrades if so. Stanza and 200b front ends are getting a bit thin on the ground these days.
Posted on: 2011/8/13 7:34
From Melbourne, Australia
Stanzas are 51mm tubes.....
They take the VL Turbo calipers or other calipers with 76mm bolt spacing.
There are two different 180B stub axles, a small bearing and large bearing type. The smalls are the same as Stanza and (I think) the original 1200 stubs.
Posted on: 2011/8/13 7:50
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Both of those are 2.0 inch tubes (B310 and 180B/610). That converts to 50.8 mm. The smaller diameter tube is 45mm, as used by B110.
There are two different B310 struts which are 50.8 mm. Is there also a 45mm B310?
Posted on: 2011/8/13 8:03
Yes it looks like the A12-models had 45mm strut and most A14/A15 had 50.8 mm strut.
What did Australia have? In USA all have the larger strut even the A12 models.
Posted on: 2011/8/13 9:25
Early 1200 had 45mm ones from memory. The stanza etc had 51mm struts. As we didn't get a-4 or a15 from factory in b110 or b120, makes no difference based on engine.
Posted on: 2011/8/13 9:28
