« 1 (2)
Re: points gap
Quite a regular
From Philippines
my spark plug gap set at 0.35 thousand of an inch and i can say it has the smoothest idle and balance power.
my points gap is set to 0.20 (thousand of and inch
i set this gap when the points are new and after 3 months it's still fine.Quote:
mcdat wrote:
thankx guys much appreciated,now can u tell me the gap for the plugs.
Posted on: 2011/8/18 9:23
1983 B120 A12
Re: points gap
From Malaysia
i set mine to 1.2mm. the plug became hotter (the plug colour is whiter).
Posted on: 2011/8/18 9:50
Re: points gap
From the 1973 Factory Service Manual:
point gap (new points): 0.018-0.021 in (0.45 - 0.55 mm)
dwell (new or used points): 49-55 degrees
Spark plug gap: 0.31-0.35 in (0.8 - 0.9 mm)
Spark plug gap of 1.2 mm will slightly misfire unless you have a high-energy Electronic Ignition.
Yes, I find the same. It is noticeably smoother at 0.035 inch (0.9mm) than at 0.031 inch (0.8 mm).
Posted on: 2011/8/18 23:49
Re: points gap
From Malaysia
i used high energy electronic ignition. tried 1.3mm, but the motor will misfire badly, so i back down to 1.2 mm, no misfire at all. the coil is warm.
Posted on: 2011/8/19 1:53
« 1 (2)
