A few questions?
From Sydney NSW
First of all i have these retractable seatbelts and can't work out where the part you click into gets bolted to? Does anyone have an idea?
Second i have this brake master cylinder and it doenst have a push rod (or what i call a push rod, the part that joins to brake pedal). Can one be bought and used or is there a better way to go?
See the photos below \/ sorry for #OOPS#ty phone quality
jpg  IMG_0496.jpg (99.74 KB)
12278_4e54481b47636.jpg 581X778 px
jpg  IMG_0497.jpg (82.29 KB)
12278_4e544824c3102.jpg 581X778 px
jpg  IMG_0501.jpg (82.13 KB)
12278_4e54482bd7001.jpg 581X778 px
jpg  IMG_0502.jpg (79.78 KB)
12278_4e5448367b0fa.jpg 581X778 px
Posted on: 2011/8/24 1:40
Re: A few questions?
It looks like someone modified your ute floor panel.
Here's a stock one showing the seat belt
Posted on: 2011/8/24 1:52
From Sydney NSW
hmmm any recommendations? is it possible/legal to drill and bolt to something?
also any info on the master cylinder?
Posted on: 2011/8/24 2:27
From Sydney NSW
So i had a further poke around and there was some plastic or something stuck over the original floor panel. Found some surface rust but overall doesnt look too bad.
So the seatbelt situation is all good.
Would love some advice on the brake master cylinder??
jpg  dat.jpg (81.22 KB)
12278_4e545f7b1b438.jpg 581X778 px
Posted on: 2011/8/24 3:18
I've got a spare brake master cylinder if you need to get a replacement.
Posted on: 2011/8/24 4:59
Win-win
Brake cylinder is more difficult. You will need to find out:
* what kind of pushrod the cylinder is supposed to have. This is give you the correct end to fit into the cylinder
* a stock 1200 cylinder pushrod to compare it with. This is the end that goes on the pedal
Cut and weld the two together. If the length is not correct, use shims. Most master cylinders require a tiny bit of play in the pushrod to work correctly, so the length is critical!
Posted on: 2011/8/24 5:00
Not too shy to talk
From Dub-Ya Aye
your master cylinder is from a 120y. I got 1 from auto 1 last week and it looked exactly like yours.
Posted on: 2011/8/24 10:21
From Sydney NSW
datsunbeginner- PM sent
DD- PM sent
did yours come with a push rod or can you buy the push rod from auto 1?
Posted on: 2011/8/24 11:20
1200 Ute
Not too shy to talk
From Dub-Ya Aye
Mine didnt come with a push rod, I modified my original one to work.
Not sure if u can get replacements.
Posted on: 2011/8/24 14:48
