« 1 2 3 (4)
Re: BRAKES FOR SALE
Ok ok ok ok ok ok- rotors Sold if Andy grabs calipers
Posted on: 2011/9/29 1:15
Re: BRAKES FOR SALE
From Melbourne, Australia
Andy.......?????
Posted on: 2011/9/29 3:34
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
Re: BRAKES FOR SALE
From Armidale N.S.W
Nah I'm good thanks
Posted on: 2011/9/29 8:38
73 1200 wagon SOLD
Re: BRAKES FOR SALE
Bump- reminder as post has got s bit long!-
For sale front brakes and rotors to bolt onto 200b struts.Calipers are toyota hilux 4 spots which have been recently recoed complete with near new pads. Rotors are DBA gold drilled and slotted solids as new.I do not have the brake lines. Chasing $330 posted
Posted on: 2011/10/8 23:21
Current Fleet-
Re: BRAKES FOR SALE
if some one wants the calipers, ill will still take the rotors. i can supply stock rotors if need be- new too! no drilled or slotted though,but brand new 200b rotors.
Posted on: 2012/1/16 11:50
Re: BRAKES FOR SALE
Hi bob I ended up with these from shoota. Was trail installing them last night And realised that the bottom most bolt on the calliper fouled on steering arm just. did that happen with you lol. it's no drama.
Also one of the dust boot seals was torn. Would that make a difference or just cause rust etc long term.
If they work like the twin pots I got off you I will be mighty pleased.
I know was long time ago thought you might.remember
Posted on: 2013/1/7 5:48
Re: BRAKES FOR SALE
Ok sorry to bump but I want to keep all info in one spot fr now and will copy to build page at a later date,
Replace seal, but these calipers have a small and large piston, the smaller piston is a leading piston and should be at he to and the dsk rotate past it first. That is why these conversions usually go on the front of the struts requiring running the struts on opposite sides of car.
This also then requires longer brake lines with banjo style fittings to ensure they have enough length at full lock and not foul on the sway bar.
This then means the hoses should be held to the strut so the don't catch or bind from traveling the full turning circle arc.
If fitting them Witth the strut In the normal rear caliper location, it means that the leading piston ( smaller piston) will now be the trailing piston.
Spoke to my brake guy today and he says this can lead to abnormal pad wear ( the pad wearing on the larger pistons edge quicker) .
It's not ideal but he says it's common on the toyotas even that have the callers in the correct orientation. The usually either swap the pads drivers to passenger side or in the same caliper inside pad to outside pad.
So others have run these in the rear and front mounted location, so I will try in the rear mounted location first and if there are major issues will get longer brake lines . Apparently vn commodore ones may work and have banjo fittings too.
Posted on: 2013/1/9 5:40
Re: BRAKES FOR SALE
(my red coupe, which went into my blue ute, then into my CA coupe - same pads all this time)
isn't the smaller piston the leading piston here?
took 3 seasons to wear pads 75% on the rallycar (most rally cars get one or two rallies if lucky), wear wasn't too abnormal
on the road/project car - there is no noticeable significant/abnormal wear after 7 years
pad wear is near non-existant with this setup
note also - vented discs with s12+8 caliper
Posted on: 2013/1/9 8:40
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: BRAKES FOR SALE
From Melbourne AUS
get it on a circuit that'll wear the pads!
in saying that, 1200's with big brakes are really good in the pad wear department.
i used to get 4-5 track days out of my pads with the small s13 single piston caliper setup,
lots of heavier cars run out of pads after a day or 2 on the track
vented is the key, solids get too hot and the pads disappear
Posted on: 2013/1/9 11:36
1973 B110 A12
Re: BRAKES FOR SALE
Thanks rc. Rotor and calipers swap will be my project the next few nights if no rain
Posted on: 2013/1/9 14:49
« 1 2 3 (4)
